Ramp object
I need to draw ramp with a high and a lenth parameters
Is it possible?
Thanks
Hi Guillaume,
There is no “ramp” object in VisualARQ. But you can use a slab instead. It can be created from inclined boundaries (as long as they are planar).
You can also create a slab from a GH style (find it attached as a .val file inside the zipRamp.zip (12.5 KB) , that you can import with the vaStylesImport command).
Ok thank you!
