I wrote about this request a few years ago, but can’t find the topic, so I make a new one with the hope that it’s possible for the “McNeel” programmers to create such tool in the future. The idea is to be able to trace a line so that wherever it intersects with a surface it will create a mirrored vector simulating how a real light ray would reflect on a mirror surface. It must be history-enabled, so that any change of the direction of the original vector (either via moving or rotating it, or by moving its control point) would automatically adjust the reflected vector upon hitting the target surface.
This is very usable in architecture and product design, as well as mould design for CNC-milling. I find it especially useful in designing car mirrors to figure out the best orientation of the side mirror’s glass relative to the driver’s head and the position of the side mirror’s body.
Currently, I do this manually using the following steps:
- Use
! _Polylineto create a line, for example, from the driver’s head to the center of the side mirror; - Use
! _IntersectCreateto create a point intersection with the target surface, i.e. the car’s side mirror; - Use
! _Line _Normalto create a line normal to the surface at the desired location; - Use
'_CPlane _3Pointto create 3-point CPlane from the original curve and the curve normal to the surface; - Finally, use
! _Mirrorto create a mirror vector that will simulate a real reflection on the car’s mirror.
The downside of the manual approach is that the reflected vector updates properly only if I adjust the original line long the XY-axis of the CPlane used for the mirror command (step #5 mentioned above). However, moving some control point of the original line in the Z-direction will “reflect” the mirror vector in the wrong direction, ultimately forcing me to repeat the whole process again. Moving the target surface will also alter the normal direction, so this also forces me to repeat the process.
Mirror vector.3dm (206.6 KB)
