Above the most simple case that annoys me:
select 3 of 6 CVs of the black Hexagon.
Gumball Position is calculated as center of the red Bounding Box.
my wish
_GumballRelocate
should offer different options to calculate the Gumball Location:
BoundingBox-Center (current default)
Average of CVs (best for shown case)
… other approaches
best fit Plane
Align to ControlPolygon
Normal to Surface
smart (automatically shows the best of above options)
it would also be great to have the this exposed to Rhinocommon - if it is not already possible.
I think Gumball Location, Gumball Orientation, non rectangular U-V aligned Gumball for Surfaces, saved Gumball Location, …
this would be a great - and relative straight forward - field of enhancements for V9
The Gumball is certainly off kilter. I mean, how hard can it be to orient on a plane?
What I really dislike is that, if you relocate the Gumball to a specific location, next time you’ll want to use it, it is no longer there. I mean, why is that?
if ever a developer manages to read this topic:
on top of the actual orientation, there are serveral topics around, that wish to remember a custom gumball orientation.
it would be nice to have a stored gumball location
entire objects
… super hard i know: for combined selections / sub-selections
at least for named selections
groups
instances of block s → all instances should have the same new or reset gumball location.
The gumball does save its location on the object always in object mode. When reselecting after a transformation or gumball relocate the gumball will align itself to the saved orientation.
This one is tough for a variety of reasons.
We have RH-51735 open about this. It’s difficult for the same reasons as the previous. I added a note to the issue.
This is implemented in the Rhino WIP.
The default object alignment for block instances is to their instance transform. Is that what you are expecting?
I thought of the following sample - but after thinking over it, i believe another feature will be much nicer: “BETTER suggestion - redefine Insert - CPlane” - see at the end:
Gumball to Object, Block
a super simple cylinder as a block - the default Object Gumball Orientation
after setting a new Gumball-Location for a single Block Instance - other instances should inherit it. If you reset the Gumball-Location this might also affect / reset all Block instances…
this is just an idea, but i like it, from a user point of view i think it would be great.
BETTER suggestion - redefine Insert Point / Insert-CPlane
ok but the usecase i think of could be solved with a even more powerful feature:
Redefine Block Insert-Cplane / update Insert Point, with the default option of keeping the placed geometry where it is - by updating the instance-Transformations as well.
as far as i remember this feature was already wished somewhere.
