I think a Full Screen Mode With Menu Bar like in Photoshop would be useful.
The current Rhino also has a FullScreen command, but only the viewport goes full screen, not the toolbars.
I’d like to see this implemented if possible.
Best regards.
Best regards.
Use hypenated command -Fullscreen to get command line options of what UI elements should remain visible in fullscreen mode.You can make macros for various combinations as needed.
Is it possible to hide the taskbar in 1920x1080 resolution?
Hiding the taskbar in Windows settings does not change the size of Rhino’s screen.
I was able to set it up.
Thank you.
