Flow
this topic asks for a functionality similar to autodesk / alias “edit by curve”.
A complicated workarround would be possible, but lacks the support of flow command’s history for CVs.
My wish: Flow should support History, also if not the entire object is selected but also for sub-selections and CVs (of SubD and Nurbs !!)
Example: (same as in post above)
_dupEdge to get a basecurve (green)
draw a targetcurve (or _rebuild, move CVs…) (blue)
history on
_flow edges or CVs of the SubD based on the green, along the blue curve (preserve structure, stretch)
now it would be great, if i could modify the blue target curve - and the SubD’s CVs would follow.
subD_flow_history.3dm (94.6 KB)
advanced CV Editing
Above is only an example of some possible more advanced tools to edit CVs. (both nurbs and subd)
(I know there are workarounds for some of them…)
Some Ideas:
- better _matchSrf as discussed already
- lock single CV’s
- setPtPolar as discussed here
- bring together weld, stitch, aling
- _reflect and _radiate for nurbs-Surfaces and curves
- Planarize / straighten rows of CVs, similar to the planarize option of _blendSrf
- Equality distribute CVs (keep typology) internally, along U or V, along Curve, on target Surface
(Edit - added:) - @skysurfer MoveUVN instead or in junction with the Slide
- Allow cageEdit of CVs (see here)
- … what else ?
kind regards -tom
