I not so far as I know have been thought to enhance this command.
Extend multiple edges at once, not just one at a time.
Allow the user to choose, by option, if the result assemble or maintain the extended separate parts (this can be important because we understand visually how the area has been extended).
Give the opportunity, where permitted, to extend an area up to a limit, which is a point, a curve, or otherwise.
If possible, introduce a dynamic preview of the results, a little as with the extrusion command (type handle), more functional.
Hi Davide - in V6 you can dynamically extend edges - still only one at a time, but the
*ExtendSrf
repeater macro works very nicely.
I am not sure how to extend to a limit - what did you have in mind, as input, keeping in mind that some parts of a surface may extend more, in 3d, than others?
Hello Pascal.
A mode of extension of this type would be much more convenient (from Alias surface).
As for the boundary edge, it could be up to a surface (where possible) … if I can find a video I’ll show you.
