Wish: display modes in layouts etc
Hello!
Layout space supports display modes. This is well and good, because the only way to place an image/picture in a layout is via a textured nurbs surface, and thus a shading mode displaying textures must be available.
However, the available display modes are missing in the viewport menu. The only way to change it is via command “SetDisplayMode”, or a keyboard shortcut.
  • 1, wish: Please show display modes in the viewport menu of layouts:
  • 2, wish: Please also show display modes in the viewport properties panel of model & detail space viewports! More obvious this way than just via the viewport menu.
  • 3, wish: The command “SetDisplayMode” does not show a list of the available display modes like e.g. “SetObjectDisplayMode” does. You need to know the name of the mode and type it in.
    For consistency’s sake, this list should be shown in the command.
  • 4, wish: These toolbar icons
    don’t seem to work in layout space, whereas keyboard shortcuts do. There’s even an error message “Only model views can be rendered. Please change to a model view.”, which is obviously wrong.
    Can you please make these icons work, too?
  • 5: the command “SetObjectDisplayMode” is missing certain available display modes.
    I guess this is due to technical reasons of the display pipeline, which cannot mix, say, artistic, and wireframe etc.?
    However, my custom display modes “ConstantByMaterial” and “ConstantByObject” don’t show up in the list, too.
    ConstantByMaterial.ini (12.9 KB)
    ConstantByObject.ini (12.9 KB)
    Can you please tell me what’s so special about them that they cannot be mixed with other display modes?
Thanks!
Pictures should work just fine in layouts without any display mode adjustments.
You are correct! When I d&d a picture into a layout, a surface is created, and it’s texture (with a ‘Picture’ shader) displayed.
But still…
Out of interest, I created a plane by hand next to the picture in the layout, and assigned the exact same picture material to it - the texture is not shown. Just the wireframe of the surface.
I turn on ‘shaded’ mode via shortcut (which definitely shows textures in model space), the plane is shaded in white, but still the texture does not show up.
Why? What’s the magic behind the d&d-ing in a picture?
Does some object displaymode get set automatically for the object? If yes, which one?
You can select the surface and SetObjectDisplayMode to Rendered.
https://docs.mcneel.com/rhino/7/help/en-us/index.htm#commands/picture.htm?Highlight=layout%20picture
Okey… (should’ve read the f’in manual… also, I should get into the habit of browsing youtrack).
I just learned that in model space ‘display mode’ parameter is exposed in the properties, on object level, as well as for the viewport itself. Very nice!
For details, there’s a youtrack entry already.
Still I wonder why for layouts, it is not. What’s the policy here? Users are not supposed to use display modes for the whole page, even if it’s working already with a trick (keyshort)?
In general it is best if users do not use alternate display modes for layouts. This allows the page geometry to be output as vector when printed while the details can be a mix of vector or raster based on the display mode of the detail.
Duh… that even makes sense. =}
That is arguing based on what is perceived by the user as a bug.
I always wondered why Rhino7 sometimes ignored printing as vectors from Layouts even though i had “vector” specifically selected in the print dialogue. I found by accident that it has to do with display modes.
This explains it.
I considered it a RH7 usability bug that it would not print vector lines even though it was selected.
But i also consider the removal of display modes for layouts in RH8 a crude workaround that has even worse implications.
When layouting something, my expectation is that i can have a wysiwyg mode where i can see what i am doing before printing. As a user i expect a white page, not a grey one. Who prints on grey paper? My expectation is also that i can see the print colors and line width, basically that is all what layouting is about.
Changing the background color in wireframe mode to white does not do anything in RH8mac for the actual page color.
Settins->Appearance->Layer settings background does nothing as well to the actual page color.
So really the only way to edit layouts with correctly displayed colours currently is to not use Layout views at all and instead use a normal viewport for it and screenshot/print from there. This is a huge regression compared to RH7 for me.
I don’t understand what you mean here. Could you please explain?
