Hi there,
Working with dense meshes, I often find it quite difficult to transform objects because of the wireframe getting in the way of shapes, even in Rendered or Shaded modes. I see many other users here struggle with the same issue.
We figured out a way to disable selection highlighs and toggle them per-display mode in such cases, which helps a lot, but the other problem is the ‘locked’ wireframe that Rhino always shows when transforming objects.
In most cases naturally this “orginal” wireframe is very helpful as a reference or a geometry to snap on, but there are models and cases where it is not needed and just occludes everything with no way to disable it.
Could we please have an option (either global or per-display mode) to not show these “original” wireframes? It would be really helpful, and also I am guessing may be easier to implement than the alternative selection highlight methods.
thank you,
–jarek
