I apologize in advance if the topic already exists here, but I couldn’t find it.
Is it possible to not display the wireframe when selecting an object? For example, I have a rendered view and I select an object, but I want to highlight only its outline for clarity.
You could try the Rhino.Options.General.SilhouetteHighlighting advanced setting to see if that works better for you. There are a few other “SilhouetteHighlight” settings, so you can search for that term to find them all.
Apologies for delayed response. Unfortunately I do not see an option for SilhouetteHighlighting by following the path you recommended (Screenshot below - I am using Rhino 8 (most recent update)) . There is an option for Show surface Isocurves - but that did not help for this issue.
