Wish: Coloured control points
Hey Dev Team, wondering about having control points be a different colour when the weight is something other than 1. Would be very helpful to be able to identify alternat weight control points quickly. Thanks!
Depending on the colour, some colour-blind people may have difficulties to identify the coloured control points. Coloured objects nearby also will change the visual perception to e certain degree.
An alternative way is to make the control points with a modified weigh be the opposite type of the one used in the active display mode (if normal control points are round, then modified control points are square). Another way is to make the modified control points triangle.
Perhaps the most realistic and quick-to-develop approach for the developers is to use a selection tool which lets you select all modified control points.
RH-21211 is fixed in Rhino WIP
Hreat! Is it possible to select all control points with a modified value at once? That will help identifying those control points easily.
