Would love to see an aplha option for mask background.
Masks can help a lot with eg. text over dense drawings, but then again, if the text is extensive, it blocks too much of the info hidden below.
cheers,
Daniel
cheers,
Daniel
Not sure if I get your question correctly, but you can add a color with transparency to a _Text. Is what you want different from that? If so pls. post a picture.
Hi @Gijs,
You can transparency to the text, but you can only apply solid colour to the mask. I believe the request is to be able to add transparency to the latter. I’d second that request.
Regards
Jeremy
Yes this makes sense to have
Logged as RH-71772 wish: alpha for Text Mask color
