I’m looking for some help with applying a mask to text. (Very new to Rhino, apologies if this is an easy fix!). I’m trying to use solid colours and the mask doesn’t seem to cover all the letters?
It looks fine in the paper space, the problem only starts when I check the print preview, or actually export to a PDF. See screen grabs below
Hello - can you please post an example file - just one or two bits of text that shows the problem, not the whole project.
Please also run the SystemInfo command in Rhino and copy/paste the results here.
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1650 (NVidia) Memory: 4GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Hello - thanks. SystemInfo looks pretty straightforward to me. I do not see anything, so far, like what you show. Are you printing using the Rhino PDF driver? Does it make any difference if you unhook the secondary monitor?
I played around a bit more, it seems I only have an issue with one specific font (Kiona, with the aquamarine mask). If I test the mask with other fonts it seems to behave normally. See screen grab below
(Pascal- yes, I’m using the Rhino PDF driver I think? Unhooking the second monitor didn’t seem to make any difference).
That font is not a standard font on Windows. If you really need to use that font, it looks like you’ll have to use a workaround by using a colored hatch.
