Wish: Add block transform data to Text Field options
Continuing the discussion from Calculation does not work with decimal:
In annotating Block Instances, it would be helpful to be able to include the Block Origin, Rotation and Scaling values in the annotations. For example. @nsgma would like to be able to derive level values from the Z co-ord.
Hi Jeremy -
Some way of being able to create elevation markers is on the list as RH-70510 Wish: Text Field Point Distance
Thanks,
