Hi, When I assign a mesh it displays a rendered view, is it possible to display wireframe or shaded? Reason I ask is that I want to see all of the mesh edges on a mesh.
I use a Mesh Preview component from the Intralattice plugin which shades the mesh and shows the mesh edges.
You can also use Custom Preview from the Display toolbar to shade the mesh and then use MeshEdges component to show the mesh edges.
[EDIT: Apologies… didn’t see the Shapediver tag]
There is only rendered mode in ShapeDiver at the moment. I backlogged the wireframe mode feature and will get back to you when we have updates on this.
You can use mesh edges as martynjhogg suggested but depending on complexity of your mesh you might experience performance issues.
