Wirecut won't work
try and wirecut but nothing happensLilliput Screen 10 inch.3dm (60.8 KB)
Hi @jamesc
I don’t know what it is you are trying to achieve, but wirecutting through the 2 solids - using the inner curve - works just fine here. There’s also an open polysurface lying beneath the two solids - this will not get cut unless you specify the distance of the wirecut (don’t press Enter to cut all the way through). What exactly are you trying to achieve and what steps are you taking?
Lilliput Screen 10 inch JNN.3dm (233.7 KB)
HTH, Jakob
It’s fine I’ve worked it out thanks
