Wirecut helpr
3d model.3dm (3.2 MB)
hi there im trying to wirecut some of my contours and can’t seem to make it work. I was able to wirecut a closed curve but not an open curve,
please help!
Hello, I’m not sure if I understood your goal correctly, but I managed to split the relief by an open curve using the _Split command on the Top viewport. Chloe Joubert, is this what you were trying to do?
3d model.3dm (3.3 MB)
you can always extrude a surface and then use a boolean split in cases where wirecut fails.
