1.when rotating, and press Shift to activate Ortho, the Snaps Guide Ticks used to show up perfectly aligned to CPlane. Now, seems like the alignment is calculated from the point where initial mouse click was while rotating using the gumball. (tried changing every possible options under Snaps, but didn’t help)
has been fixed! thnx!!!
changing Thumbnail Icon size in the File Explorer is broken (was fixed briefly)
Grasshopper: mouse click selecting component from the pop-up list doesn’t work. currently have to scroll to selection with arrow keys
@yelenaye FYI, this issue is closed and set to ‘won’t fix’
The behavior is dependent on Gumball Smooth or Snappy and this hasn’t changed (same in Rhino 7 and 8)
Show that ortho is active
Show if you have standard 90 degree ticks or more
Show approximately where you need to land with your mouse cursor to get the angle you are after.
