Is there a problem with WIP 6 update system…? For the past several days each time I open WIP 6 I get << An Update is Available, Install Now >> notice but clicking it only stops starting-up process and nothing else. When checking Help –> Check for updates, it tells me Rhino is up to date but if I click Check Now link anyways I’m getting Server Error page.
I’ve had something like that happening in the past as well. You are running an older version so you might as well just download the latest (2016-06-07 - 6.0.16159.13001) from the link in the Welcome thread here on Discourse.
(or check your C:\ProgramData\McNeel\McNeelUpdate\DownloadCache folder first to see if that version was downloaded at all).
Problem solved thanks to wim… the latest version was indeed sitting in the cache folder. now when rhino starts I get no more alerts. Nice.
BTW, what is the current policy on bug reporting. I realize that serious coding is still ongoing so wouldn’t want pollute this forum with minor quirks pestering developers, but since I’m using WIP 6 for serious projects now there is always something new popping up. Mostly I can work around it or just ask Rhino 5 for help but occasionally I’m tempted to wail in the open…
