I have been struggling with Rhino not responding whenever I try to run my gh script. I finally cut it down to just one function of my entire model and I still have issues as shown below
I have a feeling that the issue is related to the breps I am trying to move but i don’t understand what the exact issue is. Attaching the gh script, I hope someone can shed some light on this matter. M1.gh (2.3 MB)
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon RX 6600 XT (AMD) Memory: 8GB, Driver date: 6-22-2022 (M-D-Y). OpenGL Ver: 4.6.14800 Compatibility Profile Context 22.6.1 30.0.21023.1015
> Accelerated graphics device with 6 adapter port(s)
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #1
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 6-22-2022
Driver Version: 30.0.21023.1015
Z-Buffer depth: 24 bits
Total Video Memory: 8176 MB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\TeDAsharp (ce983e9d-72de-4a79-8832-7c374e6e26de)\0.1.0.0\TeDaSharp_050.rhp “TeDAsharp” 0.1.0.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Bullant\1.6.1.0\bullant.rhp “bullant” 1.6.1.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Karamba3D\2.2.0.15\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoETABS\0.3.41.0\ggRhinoETABS.rhp “ggRhinoETABS” 0.3.41.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoSAP\1.5.50.0\ggRhinoSAP.rhp “ggRhinoSAP” 1.5.50.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoSPACEGASS\1.2.30.0\ggRhinoSPACEGASS.rhp “ggRhinoSPACEGASS” 1.2.30.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoRobot\1.3.14.0\ggRhinoRobot.rhp “ggRhinoRobot” 1.3.14.0
I apologize, I was wondering if that’s the reason why there weren’t many responses to this thread after i sent my system info. I do know that not using a paid license for any reason is unethical/frowned upon, and I use this only to learn since I cant afford a license at the moment. Would this run for sure if the license was paid for? Unfortunately there are a couple of things I cant figure out on grasshopper by purely reading books and watching videos (the only resources that are currently financially viable). Again, I sincerely apologize.
@davidcockey the issue arises when the brep is connected to the move component. It will not be connected in the file I shared because I couldn’t get that far.
I do want to add as an update that I manage to get this running without an issue when I used a grasshopper script that did not involve using elements edited on rhino. However, I don’t understand why baking a model, editing it on Rhino, and then adding it back to grasshopper creates such a big issue for me.
In my larger GH script i am moving the Breps by a distance that is = half of their individual lengths. This is to create grooves in a waffle structure. But the whole script kept crashing and i managed to isolate the problematic part to the section of the script that i provided. The original “cut” breps generated has to be modified a bit on rhino so i did that. It was when I brought it back to grasshopper that I started facing issues.
I hope that explanation made some sense. Tbh its a little hard to explain
Sorry I’m having a little trouble understanding… the brep input has the 1000 ish pieces and then my out put is to have them moved upwards. Is that what you are referring to?
Yes, and for each 1 (one) of those 1000, you are generating 1000 outputs. That’s adding up…
You’ll have to look into using data trees in Grasshopper. There are plenty of links to tutorials from many of the other threads in this forum.
