Rhino and Grasshopper stop responding after a certain component ( Vector Display) was added to the canvas.
heksagonale.3dm (164.3 KB)
heksagonalna mreza_1_.gh (6.9 KB)
While using Grasshopper Rhino stops responding. Otherwise, it handles large files without any issues.
In Windows Control Panel > Power Options, a “High performance” option is set.
Here are the details:
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
Primary display: Intel(R) UHD Graphics 620 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: Radeon ™ 530 (AMD) Memory: 4GB, Driver date: 4-28-2022 (M-D-Y). OpenGL Ver: 4.6.14830 Compatibility Profile Context 22.6.1 27.20.20912.1002
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 4-28-2022
Driver Version: 27.20.20912.1002
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Orca3D V2\Orca3D.rhp “Orca3D” 2.0.23.0
C:\Users\mirop\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Users\mirop\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SubstanceImporter\2.0.1\Substance.Win.rhp “SubstanceImporter” 2.0.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Users\mirop\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
C:\Users\mirop\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Meanwhile, I have updated the Intel drivers so they are up-to-date now.
for testing purposes please disable the 3rd Party plugins in Options>Plugins
I also see that you have a Radeon video card, note that the drivers can be problematic and you may need to uncheck GPU Tessellation in Options>View>OpenGL
Did what you suggested, but Rhino is still not responding.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.28.23058.3001
I didn’t catch this aspect. Is this a particular file? can you tell us a little more about this?
The problem with response occurs while using Grasshopper, otherwise, I can work on large files without a problem. The gh file is only 7 KB and 3dm file is only 150 KB in this case.
I cannot help you with this
You will need to contact McNeel.
Thank you goodbye
Please start a new thread in the Grasshopper category with the files. I’ll merge the conversation over to that thread. Thanks
If you take 753 branches with 6 items each against 753 items in one branch you will get a half million vectors, all trying to display. Always be mindful of your inputs when dealing with trees, least you create a lot unintended items that will slow the best machines.
Lock your solver and graft this input.
Thank you for your help. Obviously, I forgot to Graft Centroids in the Area component and then I was blocked.
