Not responding on almost every file
Hi all,
I have recently been having an issue where I am having multiple instances of GH and Rhino going ‘Not Responding’ and never recover when plugging in nodes.
This doesn’t appear to be specific to a single GH file, it happens on every thing I open.
Does anyone have any insight?
Thanks in advance for your help.
Hi @harry7,
You might consider running Rhino’s SystemInfo command and posting the results in a reply.
– Dale
Hi Dale, here is the SystemInfo response -
Thanks,
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [79% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 4-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 531.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 1-10-2023 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2023
Driver Version: 31.0.15.3161
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Hi @harry7,
That all looks well and normal. Are you using any 3rd party GH plug-ins?
Is this something you can easily repeat and provide steps to?
– Dale
Hi Dale,
Attached is a screenshot of the plugins I have installed.
This issue has started recently without any new additions in plug ins being added.
It’s also not something that is replicable in terms of steps, but happens consistently when using any input / file
Hi @harry7,
That’s quite a load.
You will want to start by removing all of the 3rd party GH plug-ins (just move them to another location) and start Rhino and GH. Do you still get the Not Responding message. If not, then close Rhino and put one of the GH plug-ins back and repeat until you find the offender.
– Dale
Could this be related? Same Rhino Version, similar behavior.
Could be,
Did you check ram usage?
In my case it takes a couple of hours before things start freezing up
