Hello Guys,
I am having an error message when I start GH. Does anyone know how to fix this? Thank you
Rhino Version (Version 7 SR23
(7.23.22282.13001, 2022-10-09)
Hi -
Move the contents of the Grasshopper plug-ins to a different folder and then launch Grasshopper again. Does that error message still pop up then?
Hi Wim, yes, I tried that, still having the same issue. Not sure if there is something else that I can try. Thanks
Hi - Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim, here is the system infor. Thanks
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Commercial, build 2022-10-09
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 3-17-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.15
Secondary graphics devices.
Intel(R) UHD Graphics 750 (Intel) Memory: 1GB, Driver date: 4-3-2022 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-17-2022
Driver Version: 30.0.15.1215
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Users\linb\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.23.22282.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.23.22282.13001
Hi -
I’m not familiar with Lumion and ElefrontProperties - do they add Grasshopper components? As a quick test, I’d disable these in the Rhino Plug-In manager and restart Rhino.
Apart from that, when you use the GrasshopperLoadOneByOne command, are there any other 3rd party plug-ins asking to get loaded?
Hi Wim, thanks for the prompt reply, I just leave the office. I will give it a test on Monday!
Do you have a recent WIP installed?
I do install the latest WIP version almost weekly, so yes, I do use the latest version. As I read into the changelog, this problem looks like it was fixed. Personally, didn’t tried because I resolved this issue by changing the .NET runtime used and that solved the problem.
