Window does not trim multi layer wall lines in plan views
This has probably been discussed before, but I couldn’t find a thread…
visualarq
Hi @dora.varszegi,
This could happen because the wall style has the wrapping at openings value set to None.
Let me know if this works.
Kind regards
Hi @dora.varszegi,
The window is actually trimming all the wall layers, but the lines you’re seeing are the edge between the layers.
As @RamonC suggested, enabling openings wrapping should fix the issue. Adding a sill to the window or making the frame depth equal to the wall thickness should work also.
Enric
Thank you for both of you taking your time to help. I just checked, unfortunately it looks like wrapping of the openings is set to exterior. Yes, indeed it is the edges bleeding through.
And subcomponents wrap at ‘ends and openings’.
Hi @dora.varszegi ,
If this is still not working after you changed those values, please send the model to visualarq@asuni.com
