Why won’t this weld?
do you know why this mesh example.3dm (59.6 KB) wouldn´t weld?
Vertice seem coincident, tolerances are way above. I must be missing something really dumb.
Thank you for your effort
I can’t tell you why it doesn’t weld.
However, you can run the _AlignVertices command and then weld the edges.
Thank you for the tip. I´m not really working with meshes that often so I learned a useful command today. So far I was aligning vertrices by scaling them to 0 but since they seemed coincident this didn´t work. Probably something microscopic went astray. It´s strange that increasing tolerances didn´t solve the problem then though …
