Hi, does anyone know why some of my walls are attached to my doors and windows, especially their frames? I wanted to separate each part of my house from being attached to each other. Does anyone know step-by-step how to separate and detach the doors, windows, and their frames from the walls? If so, please help.
It looks to me (I am not even close to a Rhino modeling expert… I use it as a UI for engineering problems) like you have a building defined by its walls and cutouts.
So you have a solid wall with cut out window pieces. It looks like some extrusions were created to do the work.
Breps are basically a surface with corners (vertices), edges, and faces.
