Why SketchUp model or other software model crashing rhino
  1. when I import SketchUp model or other model is causing lagging and crashing the rhino9. (the fact is rhino is using nurbs not crashing but SketchUp model and 3ds max and other etc… cause crashing.)
  2. why it happens how to solve that problem.
  3. 3ds max handle more polygon like that rhino can handle it? we have any option for that?any method or command ?
Hi from outland -
Please post the entire output from the Rhino SystemInfo command.
Rhino 9
Expires on: 2027-02-07
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.2
Hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce GTX 1650 Ti (NVidia) Memory: 4GB, Driver date: 11-21-2026 (M-D-Y).
Integrated accelerated graphics device with 1 adapter port(s)
  • Laptop’s primary display device
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-29-2021 (M-D-Y).
Integrated graphics device with 3 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V9\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 9\Plug-ins\Commands.rhp “Commands” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9\Plug-ins\MeshCommands.rhp “MeshCommands” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.1.26314.9001
C:\Program Files\Rhino 9\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9\Plug-ins\SectionTools.rhp “SectionTools”
it crashing becasue sketchup(Mesh) 3ds max (Mesh) models and other models and also v-ray crashing (I IMPORT SKP AND 3DS FILE)
for that i need solution
rhino model .3dm (NURBS) are smoothly working eyc..
What is actually happening when it “crashes?”
Can you get an IFC file out from SketchUP? Newer versions support IFC. That can produce a better result in other applications, although I have not tried a converted IFC in Rhino. Unfortunately you would need to find a converter to get IFC into Rhino.
Maybe this one will work? … I have not tested it myself. I’ll dig up an IFC file to test it. IFC to 3DM Converter Online (Free) | Convert 3D
You keep on cutting the top lines of the report every time you post that information.
It doesn’t look like you have ever downloaded Rhino from our site.
It would help if you send in the crash report when Rhino crashes. I’m not seeing any reports from you.
Please report crashes with V-Ray to Chaos Group.
Does Rhino crash right away when you import one of those files? If not, what are the steps that you take before the crash? Please either post or upload one of those crashing files.
ITS COMES OUT WHEN a greater NUMBER OF IMPORT MODELS MAY BE 5 SKP MODEL OR 3DS 5 OR OTHER
LOL
Rhino 9 SR1 2026-11-10 (Rhino 9, 9.1.26314.09001, Git hash:master @ e7a246f3aefa1afad39e4dc6c2abb31fa5ca4d6f)
License type: Evaluation, build 2026-11-10
License details: Cloud Zoo
.NET 10.0.2
DirectX Settings
Safe mode: Off
IT JUST CAME OUT
YES AFTER 5 TO 10 SKP MODEL
What happens? Does a window pop up telling you that Rhino has crashed or does it just close?
IDK
WHAT IS IFC
I don’t understand what that means.
Please post or upload those 5 to 10 files.
IFC is an industry standard for exchange of architectural models in a non proprietary format.
How was your original model created? If the blocks/instances definitions are lost, the components may have been converted to separate meshes. That would massively increase the file size. Unfortunately the link I posted for an online IFC to 3DM converter did not produce good results.
DWG exported from the original application may provide blocks/instances when imported into Rhino.
