Rhino Crashes when Saving as SketchUp
I’ve been tring to save the Rhino file as a SketchUp file to use it in Lumion. However, each time I click the save button Rhino crashes, closes the file and there appears an error report window. I’ve tried SelBadObjects command, tried to export the file, copy pasted it into another file but nothing worked and there is a jury waiting for the renders.. Any advice would be mucly appreciated. Thank you!
You might run Rhino’s SystemInfo command and paste the results here and send the error report to McNeel.
Does this happen with a specific file? If you create a simple model with a few boxes, does the export crash Rhino with that model too?
There were many little mesh objects on the file. I just deleted them and cleaned the model a little. It worked. Thank you so much for your help!
We would love to be able to repeat this crash if you are willing to share a model that does this. Usually if we can repeat the crash, we can find and fix the bug.
No idea whether or not it is the same crash, but there was a crash on SKP export fixed in the last week or two - the fix should be in SR12 I think.
https://mcneel.myjetbrains.com/youtrack/issue/RH-49784
Hello! Maybe it’s too late but want to share this info here:
A common reason behind this is the presence of some curves in your data. Delete or hide them and you will be ready to go.
See you around,
L
Rhino 8 SR28 2026-2-10 (Rhino 8, 8.28.26041.11001, Git hash:master @ b7874a05a6982d0419fcc4f6009b510b48a09cb3)
License type: Evaluation, build 2026-02-10
License details: Cloud Zoo
Expires on: 2026-05-26
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.21
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 5070 Ti (NVidia) Memory: 16GB, Driver date: 12-2-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 591.44
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 9-25-2025 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
  • Secondary monitor attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-2-2025
Driver Version: 32.0.15.9144
Z-Buffer depth: 24 bits
Total Video Memory: 16303 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.28.26041.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.28.26041.11001
to sketchup.3dm (12.5 MB) im trying to export this into SketchUp but it crashes every time, please help.
Hi Binoy -
Thanks for submitting that file. This crashes here on Windows as well and I’ve put this on the list of the developer for a closer look.
→ RH-94113 File IO: Export to skp Crashes
Where did this model come from? The underlying meshes of planar objects, like the roof, are extremely complicated. Select the roof and run the DeleteMeshNgons command and you’ll see what I mean. A mesh that could easily be 1000 or less faces is 100000 in your model.
That being said, Rhino shouldn’t crash. The code that attempts to make adjacent, planar Rhino mesh faces into a single skp faces is crashing because of over recursion with your model. I’ll make a fix by tightening the recursion limit. That may make SKP export output for your model less likable but you should no longer crash.
Tim
RH-94113 is fixed in Rhino 8 Service Release 31
