I just updated to latest Rhino inside and I found it misses the mesh to topography component. I saw a new toposolid which is not clear how it works. The mesh-to-topography component was the only way to create revit geometry with exactly the same triangulation as the source file. Then it was easy to convert this mesh to toposolid. Why was this component removed?
where can I find the old version with the mesh to topo component?
Hi @ar00302,
In Revit 2024 there is no way to create a Topography Surface from the UI, the new type for Terrains is Toposolid
The component is still there but hidden. Type hash # Add Topography (Mesh)
on Grasshopper to create it but the resulting Topography will not be editable by Revit.
thanks
