I really see no reason to block the whole polyline/curve when adjusting its control points. I guess this kind of editing lines/curves abridges freedom of action. Do you agree?
Vlad
Hi Vlad- with no command running, turning on control points stops selection of any top level object in Rhino.
Pascal,
It might not be a bad idea to have Shift+Ctrl sub-select (super-select) objects that have (solid) points on.
-Willem
Hi Willem- yeah… I’ve been mulling whether to make some such suggestion. A kind of reverse sub-object selection that only gets the top level object. I am not sure what the details might be- presumably all sub-objects for the top level object would be deselected, I do not see any utility except for the various types of points-on situations- I guess it could not hurt except by using up a rare free key combo that might be better used elsewhere. Pondering…
Hi Pascal!
Here is an example: I often need to move somewhere a line/curve with NOT SELECTED control points which are already turned ON. So first I have to OFF control points, then move line/curve and then turn them ON again. Wouldn’t it be simplier to click on any free of points segment of the curve/line with control points ON and just to move it wherever I want to in virtual 3D space? I think that would be good for any other kind of rhino`s objects…
Best regards,
Vlad
Hi Pascal,
I think if we let go of the Sub in Sub-Object Selection, replace it by Alternative or Alt or anything indicating a type of selection not in the primary “layer” of select-ability, it might not be much of an issue to add control/solid point objects with Shift+Ctrl.
For me Shift+Ctrl is a natural grip to select non-selectable (sub)-Objects any new combo just for this would IMO be a waste of shortcuts.
my 2c
-Willem
