Hi, I got a strange behaviour when using transparency in VRay:
I use a png for the diffuse color and checked the option “diffuse texture alpha” to get the alpha values from the png. It works, but when I render this material in front of a darker material, there always is a white border. How can I avoid this?
I tried also a png without transparency plus additional black/white transparency map - same issue.
Maybe the transparent area is to small and the soft anti aliasing cause that the background color from the PNG is visible. Do you get a white seam if you use the transparency map, but you use a green color instead the texture at the diffuse slot?
Create a Generic material (1) with the png as diffuse color
Create a Generic material (2) and change the opacity to “0”, so the material is invisible
Create a Blend material: use the invisible material (2) as base material and material (1) as coat. Use the transparency map as blend map.
I see two ways to fix it - create a transparecny map where the transparent area is larger or add an other background color at the diffuse texture. I would try to make it green.
Thanks for your effort Micha!
I tried it with a solid color (no png involved), it is the red one above → white border. And the transparent area is quite big, making it bigger should not have any effect.
For now, my solution seems to be the blend material, even if I don´t understand what is going on exactly.
