When a section is taken using a clipping plane is it possible to reference the edges of entities exposed through the use of the plane to build other entities?
Do not know if there is something like… CutToSectionPlaneCopy.
But, RObert you can just make a stndart cut where the section plane is at the exact moment in place. Of course do it on a copy object to layer first to preserve the original build.
Hi Robert- for now, you can extract the curves along a clipping plane as curve objects using the ClippingPlaneCurves script here:
http://wiki.mcneel.com/people/pascalgolay
Thanks Pascal, I will give it a try.
