Previously, after pasting, Rhino would leave my selected objects selected.
Thanks!
Thanks!
Hello - as far as I can see Paste leaves the objects selected here. If it does not, for you, can you test in a new file, make a box, Ctrl-X, Ctrl-V - is the object selected?
What you described is what I expect (and have experienced in Rhino before), but in my version of Rhino, as soon as I “Ctrl-V”, the object(s) are unselected, it doesn’t matter what type or how many objects.
Hello -
Please run the SystemInfo command in Rhino and copy/paste the results here.
Rhino 7 SR7 2021-6-9 (Rhino 7, 7.7.21160.05001, Git hash:master @ d2161989109d5dacba531310b5d345ce6f4da9f6)
License type: Commercial, build 2021-06-09
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: LAPTOP - Plugged in [93% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 1-22-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2080 Super with Max-Q Design (NVidia) Memory: 8GB, Driver date: 9-14-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.38
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-14-2020
Driver Version: 27.21.14.5638
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\mconway\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\SpeckleConnectorRhino.rhp “SpeckleRhino2” 2.1.25.5994
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21089.1448
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\RhinoBeat.7 (d6f60aad-2954-44ef-9054-904ca827b721)\1.1.27.0\Rhino_7\RhinoBeat.7.rhp “RhinoBeat.7” 1.1.27.0
C:\Users\mconway\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\mconway\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Pollination\1.0.0\Pollination.RH.rhp “Pollination.RH” 0.102.1.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.7.21160.5001
C:\Program Files\Rhino 7\Plug-ins\NamedPositions.rhp “Named Position”
Hello - I would get the most recent Rhino, https://www.rhino3d.com/download/rhino-for-windows/7/latest and if that in itself does not sort it out, disable these plug-ins in Options > Plug-ins page:
Then close and restart Rhino. My guess is it will work, and if so, your job will be to enable one or two at a time and see if you can pin down the culprit.
I uninstalled Speckle, RhinoBeat, EleFront, Pollination, and it works! Will go back and figure out which one specifically was doing this.
Hello- no need to uninstall - you can disable them in Options, then close and restart Rhino.
sorry, meant “disable”
