When Gumball cutting with a closed curve, can you reverse what is kept? e.g. I Gumball cut a cube with a circle and the material within the circle is deleted, but I want the material outside to be removed leaving a circular object. Is there some “flip” for Gumball cut?
I get it. Thanks. It would be nice if there was some sort of flip behavior for a single closed curve, but I can use that workaround.
You could also do a gumball extrude with your circle, then select both and do a quick BooleanIntersect.
Thanks. I’ve found multiple methods. I just thought there might be a one click flip/context option for inside/outside that I didn’t know of.
Seconding the wish for Gumball cut flipability - would be 100% more useful if when cutting with a closed curve if the kept surface was the inside or the outside.
Maybe with a mod-key? (doesn’t look like ALT is currently doing anything there)
also check
_wireCut
it has the flip option
Thanks - that’s a good reminder about _wireCut - it’s defintely more full-featured.
Ultimately my hope is for the Gumball gesture to be versatile as it seems like the purpose of Gumball features is to avoid trips to the command line.
When I went to test it just now it surfaced a strange (possible?) inconsistency with the Gumball cut - this was kind of surprisingly various :
(Using Gumball-cut with no mod keys pressed)
Why is it that with the left objects case its interior is removed and the right both sides remain?
