is this behavior ok?
If i rotate some curve then gumball lose “cut mark”. I must select curve again, rotate gumball and after that select curve again…
Hi @Chita
If the gumball is set to “Align to Cplane” or “Align to World” then yes, it’s expected behaviour. If you have it set to "“Align to Object” the gumball should stay aligned with the object.
HTH, Jakob
Hi, ok, thank you for reply ![]()
