What render output is realistic?
rhino renderer vs blender vs rhino legacy render?
im confused …i want suggestion what to use,
explain these renders
and which one gives realistic render?
which one gives render output like enscape and v-ray
any one this rhino renderer vs blender vs rhino legacy render output image ?
Rhino render is based on cycles, the same render engine that is in Blender, but it has not all of the features you find in Blender.
Forget about Rhino legacy render. It is no longer available in Rhino 9
blender has extra feature for rendering so even though is same engine blender output is good than rhino render ?
What do you want to render? Product, Jewelry, Architecture, something else?
for Architecture exterior & interior design and product design
Do you have any experience with rendering? If not, Rhino render is a good starting point. It all depends on which features you are looking for in a rendering engine and if you want to pay extra for it. If you are making an occasional rendering, I’d say Rhino render is fine.
If you already have some experience, give VRay, Bella, Keyshot a try. VRay is a fully integrated render engine that I personally have been using for many years. It is quite feature rich and has a large library of materials and assets.
The short answer is that Rhino Cycles is not going to match Enscape or Vray.
The long answer, is that you can get very great results with Rhino 8 and 9, but it ultimately requries a level of investment in time and skill. I would be confident in saying you can get 80-90% the way there.
I don’t like it personally, but if you do that have the time, you could try Rhino Cycles and then complement (or ruin) the renders with AI on the top.
even blender is not matching the Enscape or Vray output. ?..
Can’t speak for Blender.
I guess it has loads of random plug-ins and such that have brought it much closer. I recently saw some elements of dispersive behaviour, for example.
But there are people out there who would just use Blender Cycles for thier work anyway. For architecture, I suppose it must get somewhat close…
Personal taste for me, I tend to find Cycles renders look a bit flat. There is a reason that people still use Enscape/Corona and Vray for Blender.
i know to use enscape and vray well
but i want free render software
i dont want to waste money
* can anyone suggestion me free software for render and explain pros and cons.
I think @keithscadservices has been testing various things over these couple of years around Archviz.
He has mentioned Twinmotion as a possibility, but I am unsure of the commercial aspect for licences.
It isn’t free, but I personally use Bella Render, which is a one-time perpetual licence which can be refreshed for updates. It is CPU only at the moment, but I have seen some fantastic product and archviz results from it.
Time is money too, so if you know Enscape and VRay well, I’d stick to those. I assume you are billing your hours to your clients, right? For professional work, it’s totally worth the subscription costs imo.
Your expectations here are utterly out to lunch, no there is not some free clone of Vray just floating around that you haven’t heard of (I mean other than the fifteen new renderers a day that show up on Reddit now.)
Also, virtually anything in fact can produce excellent output, it’s a matter of what product you personally like using enough to really get good at and rendering principles(rendering is an entire vocation after all) that transcend the software.
  1. any render has 3- or 6-months trial
as mentioned, there is no free equivalent to Vray / Enscape.
for your situation Rhino’s Cylces is 99% more than sufficient and actually really good. there are some reports that claim blenders version of Cycles renders slightly faster but for a big scene in a higher resolution you might lose a few minutes at best. since Blender is free either it should not be a big thing exporting stuff to Blender for rendering purposes.
generally there are 3 major things missing in Rhino´s Cycles which you might never need in your case.
dispersion/caustics:
for renderings on that scale that is barely to rarely needed, unless you need realistic pool renderings, but here you have enough options to add caustics without heavy calculations from the render engine. and dispersion is really not anything you will ever miss. should you ever need it Blender has alternative builds for Cycles and plenty of workarounds either.
volumetric:
could add a bit but it really does not add too much either. the lights and materials of Rhino’s cycles will suffice easy without it. again Blender’s Cycles has plenty of options here.
compositing:
seen by camera/reflection etc is missing, that is a great feature that comes with other render engines but again for architectural renderings these are usually not needed and if really needed use Blender.
there was/is some hick up with 8 where bump is broken, but if you have access and can update to v9 at some point that should do just well since it seems to work there again at first glance.
of course there is always something better out there and a bunch of people go straight to AI rendering already which is fast and sufficient for many task, skips the material and lighting setup and render process with really good quality.
this is available in Rhino 9
oh lala kidding? must have a look then.
That is correct. I ended up using D5 Render the most in the end. Second was Twinmotion. I had used Enscape back in the day and really liked it (relatively good results with bad hardware) but at the time I had to choose they were having some issues porting to Rhino 8.
I would have to agree here. That’s one reason I paid for D5 instead of using Twinmotion for free - I could get results much quicker. Twinmotion was really good too and once or twice I actually used in while paying for D5 (couldn’t get something to look right for some reason).
Every render engine had pain points. I with they had UI’s more like Rhino’s. People complain to no end - they want fancy UI controls like some sort of video game.
I second D5. We used to use Enscape which was great at the time, but after it was bought by chaos development seemed to shift to revit and sketchup and away from rhino. Twinmotion is fantastic but doesn’t handle texture mapping as well as D5. So that is currently where we are at. D5 has a great free version without a bunch of the extra assets and stuff.
