What PC users get for big file sizes (6-8GB)
I relatively new to CAD I have some prior experience from highschool. But have not had to deal with the problems of serious modeling.
Running some test on system in anticipation of my drawing work I discovered my file size about 6GB in size!!! And that my computer could not manage it at all. Totally crashed all day long
I need a computer that can manage detailed design work. What do expert recommend?
What the heck are you working on that your file sizes are so big? Taking up 6 or 8 GB of RAM when opened, that’s easy for architectural scenes, but on disk?
I am working on greenhouses.
That number is just based on some test I ran projecting my needs.
Hi Justin- if your objects have repeated elements, consider using blocks for these-
http://wiki.mcneel.com/rhino/usingblocks?s[]=using&s[]=blocks
http://wiki.mcneel.com/rhino5vstatus/large_project_organization?s[]=using&s[]=blocks
Do you have a video example of using this tool?
When I have a large file AND do large renders, I can hit 10 GB easily. Files that crash are all about memory, so you can avoid crashes if you use the following:
  1. Windows 7 or 8, use 64 bit
  2. Rhino 5, use 64 bit (including any plug-ins )
  3. RAM: 16 GB minimum, 32 is good if you want run multiple apps
Avoid any 32-bit OS and apps. Your RAM / memory usage will be limited to about 3.0 GB. Anything larger = crash!
