Hi
I need advice What kind of Texture Mapping suitable for Substance material?
Detail as below
09 texture mapping for substance material.zip (14.9 MB)
Thank
Travis
Hi
Detail as below
Thank
Travis
Hi @travis.designer.vn
For the non-rounded version, simply use box mapping. You need to make sure that mapping widget match the edges of your table top, if you want the lines of the wood to flow around the edges.
For the rounded version, I would probably unwrap using only the bottom edge as a seam and the center plane as symmetry - and then adjust the UV mapping if needed. See video for M.O.
Rounded cuts through wood is always dificult using texture based materials, since they have no concept of what the wood core looks like. That’s why procedural woods are nice (although they often look like plastic!).
HTH, Jakob
[Edit: Sorry, uploaded the wrong video - the right one should be there now!]
Thank for share knowledge @Normand
first time I hear about SymmetryTip
Look good however I think because limit of this material it still not perfect
In real live, wood look like these:
Thank
Travis
