Hi
I download wood material
walnut - Nussbaum | Food4Rhino
walnut-nussbaum.zip (1.3 MB)
Very impressed, but I do not know how to use it.
Need advice
Thank
Travis
Hi
Thank
Travis
You need to apply mapping to your box. Search for ‘rhino mapping’ on youtube, plenty of good results there.
Hi @mich.platter
I watched several video, but they introduce mapping with texture map.
Did you try with this material?
Thank
Travis
Hi @travis.designer.vn
Try copying the UV mapping from the example file (MatchMapping
) to se how it’s done. Notice that the mapping type he’s using is planar (UVW) with a XYZ size of ~440. Once you’ve copied/matched the mapping, show the mapping widget of your own object (using MappingWidget
) to move it about/scale/rotate using the gumball - and use MappingWidgetOff
to turn it off again. Hope that helps
-Jakob
Hi
I try to apply to real world table top size 500x1000x25mm
I active UVEditor
Thank
Travis
Hi Travis
I noticed, that some of my wood materials get damaged, when opened in Rhino 7 (and when I look at your pictures, they seem to be).
So I updated all my materials and added some demo content. They are now available here.
I think using the UV-Editor doesn’t help you much. It is good for planar mapping of textures, but then you run into problems with the seams in your models (and even a simple table has many of them). UVW-mapping in contrast is fast and intuitive to use.
