Windows version information:
Apple macOS Version 14.5 (Build 23F79)
Rhino information:
Build Date: 2024-07-12
19:35:56 WriteClearFile starting. Filename: /Users/Shared/McNeel/Rhinoceros/8.0/License Manager/Licenses/[REDACTED].lic [ZooDebugLogging.cs line 12] Command: [none]
19:35:56 CRmaLicense::GetDaysUntilExpiration() failed (expiration date invalid) [/Users/bozo/TeamCity/buildAgent/work/[REDACTED]/src4/ProductLicenseSystem/RmaLicense/rmalicense.cpp line 1401] Command: [none]
“Windows version”? “/Users/bozo”???
The home folder is my domain! Please put it somewhere else, maybe in “Library/ApplicationSupport/McNeel”?
I had to delete this at least 50 times in the last few months.
User bozo is back spamming my user folder on macOS!
Could it be that TestEnableDebugLogging gets automatically switched on each time Rhino is updated, or crashes, or when a release candidate gets installed?
There doesn’t seem to be a keyboard shortcut that I can accidentally hit to activate it.
@diff-arch I don’t know what is going on, but I logged this to ensure it stays on someones radar: RH-85399 Reportedly debug logging gets automatically enabled
It seems like the checked option, doesn’t automatically create the file. My theory is that when Rhino crashes or fails to connect to the licensing server or something similar, it is now entitled to dump the file.
I’m scripting quite a lot in Rhino and Grasshopper, and thus do a lot of things that crash Rhino. This is not the fault of the program, but my own for not writing better, more stable code.
It’s still happening in version 8.35.26251.13002 (2026-09-08) after a clean installation of macOS Tahoe and Rhino 8. I was previously still on Sequoia.
