What is the purpose of "void" component RiR?
@Japhy - I’ve set up my definition to match what you’re showing, but still not getting any results. At first, I thought it was due to your comment about Revit-friendly curves, but I reconstructed the curve as a simple arcs-and-lines closed curve and tried extruding, with similarly no result. I then inserted a simple rectangle, as you have demonstrated, but still no void within the wall geometry. My interpretation of your comment is that the category of the New Component Family should be a generic model, is this correct? Is it possible I need to manually perform the void/cut operation in Revit after the geometry is created? In my case, placing an Element Geometry component after the New Component Family yields no geometry (which might be expected anyways if it’s void geometry…). Thoughts?
