In Rhino 7 I used to click the curve tool and then click the box “on surface” or “on curve” (under selection filter) to draw the curve on a specific surface. I can’t find these options in Rhino 8. Can someone help?
Hi Felicia -
When you hover over the OSnaps
panel and hit the ctrl key, the OnCrv
, OnSrf
, etc. snaps will appear.
There’s an issue with that panel then not reverting to the regular OSnaps
→ RH-79837 osnaps on mac flaky behaviour
… but it doesn’t sound like you are getting that far. Can you see the OSnaps
panel in your UI?
Im on a Mac. In my case, I see the changed OnSnaps, but the whole list is greyed out. Besides , I had no clue i could find this list by hovering + Ctrl. Where are such hidden options listed ? In the manual?
Hej Hans -
You need to be in a command to be able to use these.
Yes → Object snaps | Rhino 3-D modeling
thanks !
