Is there a way to snap to surface except changing c-plane?
the osnaps should offer an on surface option once you start a command like move, or curves. you start the command hit that osnap and select the surface you want to snap to.
oh and in future if you have user interface questions, then consider categorizing your topic i had to look up your posts to find out what you might be using, its not a big deal but saves time for others
there are people who have macs and may not always be able to help you exactly.
Next time I will take into consideration.
I hit and select surface but still didnt snap on it.
These are more snap options if you hover over the osnap window and press control. It is a one time option . Meaning you have to do it each time. I would look there too. —Mark
Thank you for replies. I figured out by holding ctrl and hover the cursor on the snap and enabled the PonSrf.
Hello - that snap should be available once you start the Curve command. One-shots are only active when Rhino is looking for a point.
I am trying to draw curves in plan, put they keep showing up as 3d in front view. How do I keep my drawing on the Cplane surface or in plane view only.
As far as I understand, there’s still no way to snap selected points to the surface when moving them? It’s the same retopology for curves, isn’t it? It’s a very simple and useful command!
Or am I missing something?
Maybe we can somehow implement retopo of curves on a surface, without intermediate links like _Project. So that it works as a simple retopo with the ability to then move points on the surface.
