V5
I have a surface (made from extrude curve) that runs into a mesh, that I need to intersect with the mesh.
I run Intersect, select the surfaces, but only the surface is selectable.
I try MeshIntersect and it asks me to select meshes to intersect, not mesh then surface.
How do I get an intersection of this surface and a mesh ?
This would technically not give the same result, as the result would depend on the density of the mesh. Maybe using a very fine mesh for the surface would be good enough, however.
If the mesh is not too large, use ToNURBS to create a polysurface from the mesh, and then Intersect or IntersectTwoSets the surface and the polysurface from the mesh.
If the mesh is large then Mesh the surface and use MeshIntersect.
