work with curves and _curveBoolean as much as possible.
Curve Boolean has a surface output in newer versions and got rewritten - in v7 (not 100% sure when)
dont have curves of text, also all the other boxes and bits, as they were drawn to come down and touch the surface, boolean diff wont work, trim is needed instead.
so having just selected all the crosses, again rather than trim each bit away, one command to trim the surface within the boxes would be useful.
also the insides of the bars. mass trim these items.3dm (3.7 MB)
_scale1d in front view to get more z-height - just for easier working
_dupEdge from frontview
_selDup to remove duplicated curves
_join
_selclosedCrv _hide
now clean up everything that is not closed…
_show
use the curveBoolean workflow with curves shown above.
