Is this called something else in Rhino? When I search for it on this forum I get no results.
Right now, I’m trimming surface A with surface B, and then surface B with surface A, which seems a bit silly.
Have you tried to trim both surfaces in one step?
if you select the surfaces first and then use the command, you can trim as many surfaces as you want
Oh!
For once I read the actual command line text, and me not being a native English speaker, it didn’t seem to leave me any hints that I could do that.
Thank for the tip!
