I have a button that runs the .py file from Mitch (referencing it from a D drive location)
what code needs to be added to offer a choice of translucency ?
At the moment…
I select object, I hit my button, code runs…
I choose ghosted ,
I wish to choose an amount of translucency, I bit more see through.
I need the next step to offer that.
How should I code the button after the reference line of :- ?
-_RunPythonScript "D:\RHINO 3D WORK AND ASSOC FILES\Plug-ins and Scripts\Helvetosaur setObjectDisplayMode makes a chosen object translucent all view and antidote\SetObjDisplayModeAllViewports.py
All this does is set the selected objects’ display mode to Ghosted, so you need to change the transparency setting in that mode (nothing to do with the script). Default is 35% IIRC, also not transparent enough for my taste, I have mine set to 60%.
Yes, but if someone gives you some code to run, it’s a black box/magic to you, so you will never know what it is doing. At least if you ‘manually’ go into Options for the various display modes and actually look at what the settings are, maybe you will understand it better and be able to repeat it later if necessary.
Why not just create a new ghosted display mode - say “Ghosted 50%” and save it. Then use it instead of the builtin ghosted? Like you and Mitch I frequently find more transparency useful so I created just such a mode and it works great.
Of course this would require an adventure into changing the line in Mitch’s script that sets the display mode, but I’m sure that you can master it.
