I was wondering if it was possible to change the transparency of the ghosted view via script/macro. The way you can do through rhino is using the menu DocumentProperties / view / display mode / ghosted / transparency. Do you reckon there is any way to do it while working on a python script with a rhino command?
Hi rhinorudy, maybe my answer wasn’t clear enough. I don’t just want to change the view from shaded to ghosted but I want to alter the Ghosted view’svalue “Transparency” which can be found normally in DocumentProperties / view / display mode / ghosted / transparency and wondering if could be altered via a rhino.common command or a macro
Thanks
V.
Doesn’t look like this is easily do-able, not all the display mode parameters are exposed in RhinoCommon. A possible hack may be to change the object color setting - one of those settings which is exposed - to something that has a lower alpha channel value. But I’m not sure that will cover all situations.
Edit: actually, that doesn’t work, I can change the object color alpha value, but it doesn’t affect the display. So, in the end, I don’t see any controls on Ghosted transparency exposed to scripting.
Macro-wise, the only current possibility is to have set up a copy of the display mode as Randy suggested and switch to that with a macro.
If you don’t need to change things while a script is running, then the best bet is probably just via the Display panel.
Edit#2 One other thing that might be possible is to set the object(s) in rendered mode via SetObjectDisplayMode), then change the transparency of the render material…
Currently it can be done via RhinoScript - looks like in RhinoPyhton the needed RhinoscriptSyntax methods were not yet implemented (ImportViewDisplayMode / ExportViewDisplayMode). Anyway - see attached for how it can be achieved.
