I want to create a surface between two closed NURBS curves. So far I have manage to construct it through “Loft” “Straight Sections” and “Sweep2”. In Rhino the surface looks clean, but every time I export it to STL and open it in Cura, it shows a very low poly surface.
Any idea to why this is?
How could fix this so the surface is as smooth in Cura as it is in Rhino?
Hi @Felix_Grassberger
Without seeing the file and your settings for exporting the STL it’s just guessing, but I reckon that the mesh settings when exporting might be the cause. Check out the preview when meshing and make sure that your settings match the size and detailing of the object - for something this small, it should probably be 0.002 or maybe even 0.001.
HTH, jakob
