Weird hatch bug
For some reason I am having issues all of sudden selecting longer skinnier hatch patterns (eg. skinny rectangles). Squares work fine, but longer skinny rectangles simply won’t allow me to select the hatch. If i want to change the hatch color or manipulate I must select the whole object. Any suggestions?
Hi Chris -
I’m not sure what that means. Could you post a 3dm file with such object?
Also, please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim, I am running into a similar issue. I am only able to select the hatch running the SelHatch command or by right clicking into the layer and selecting objects. I can also select by dragging a window left to right but it only works on certain locations of the hatch. Clicking the hatch itself does nothing. Strangely enough, if I change the hatch from solid to any other pattern, the issue disappears.
I’ve attached a sample file and system info.
Rhino 8 SR37 2026-11-3 (Rhino 8, 8.37.26307.15001, Git hash:master @ c4477bc788d7c2a5b543b0cd917f0dde91849957)
License type: Educational, build 2026-11-03
License details: Cloud Zoo
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 67GB)
.NET 10.0.2
Computer platform: DESKTOP
Secondary graphics devices.
NVIDIA GeForce RTX 4070 Ti SUPER (NVidia) Memory: 16GB, Driver date: 7-22-2026 (M-D-Y).
- There are no monitors attached to this device!
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
Recommended: Unplug the monitor and plug it into one of the video ports on this device:
Any hardware configuration or cabling changes you make will require that you restart Rhino.
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-22-2026
Driver Version: 32.0.16.1088
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.37.26307.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.37.26307.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.37.26307.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.37.26307.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.37.26307.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.37.26307.15001
C:\Program Files\Rhino 8\Plug-ins\SectionTools.rhp "SectionTools
Select Hatch.3dm (2.7 MB)
Hi Ethan -
Thanks for that sample!
I’ve put this on the list for a closer look:
→ RH-100354 Select: Failure on Hatch Sample
