Weird black shading for clipping plane in shaded view
I am having an issu with the clipping plane in shaded view. I am adding a video for you to see the problem. Thanks in advance !
Hi Antoine -
Please run the Rhino SystemInfo command and copy-paste its output here.
Is this also happening in a new file with just a box and a clipping plane? If not, please also attach the 3dm file that you are having issues with.
Hi, of course , thanks
Rhino 9 SR0 2026-4-28 (Rhino WIP, 9.0.26118.12305, Git hash:master @ f747d8da411cf1d70538fcd21c9bfcf397fe947a)
License type: Educational, build 2026-04-28
License details: Cloud Zoo
Expires on: 2026-06-12
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 63GB)
.NET 10.0.2
Computer platform: DESKTOP
Standard graphics configuration using OpenGL
Primary display: NVIDIA GeForce RTX 4070 (NVidia) Memory: 12GB, Driver date: 3-4-2026 (M-D-Y). OpenGL(4.6.0 NVIDIA 595.79)
Accelerated graphics device with 4 adapter port(s)
  • Windows Main Display attached to adapter port #0
  • Secondary monitor attached to adapter port #1
Secondary graphics devices.
AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 3-3-2026 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-4-2026
Driver Version: 32.0.15.9579
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Cooperlake MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\import_STEP.rhp “STEP Import”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26118.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Yes it does the same with a cube in a new file. I guess my clipping plane setting are off but i can not point out the issue
Problem_clipping_plane.3dm (279.9 KB)
HI Antoine -
What happens when you switch to Direct3D in Rhino Options -> View -> GPU.
Does that make a difference?
Hi wim,
this seems to work thanks ! (actually it was already set to Direct 3d and went back to Open GL.
Thank you very much
